Displays the contents of various text files that may be created, edited, or otherwise visible in the user-visible file system.
| --number | Specifies that all output lines are numbered. |
| -n | Specifies that all output lines are numbered (same as --number). |
| --number-nonblank | Specifies that nonempty lines be numbers (overrides --number). |
| -b | Specifies that nonempty lines be numbers (same as --number-nonblank). |
| --show-ends | Displays $ at the end of each line. |
| -E | Displays $ at the end of each line (same as --show-ends). |
| --show-nonprinting | Specifies to use ^ and M- notation, except for LF and TAB. |
| -v | Specifies to use ^ and M- notation, except for LF and TAB (same as --show-nonprinting). |
| --show-tabs | Displays TAB characters as ^I. |
| -T | Displays TAB characters as ^I (same as --show-tabs). |
N/A
Example files include ExtremeXOS shell script (.xsf), Python (.py), policy (.pol), license (.lic), and logging (.log) files.
There is no restriction on the type of file to be displayed.
CLI paging is effective for this command, but output filtering is not.
The following example displays all options and filetypes for this command:
# cat ?
  --number            Number all output lines
  --number-nonblank   Number nonempty output lines (overrides --number)
  --show-ends         Display $ at end of each line
  --show-nonprinting  Use ^ and M- notation, except for LF and TAB
  --show-tabs         Display TAB characters as ^I
  -E                  Display $ at end of each line (same as --show-ends)
  -T                  Display TAB characters as ^I (same as --show-tabs)
  -b                  Number nonempty output lines (same as --number-nonblank)
  -n                  Number all output lines (same as --number)
  -v                  Use ^ and M- notation, except for LF and TAB (same as --show-nonprinting)
  <filename>          File name
    VZbase.pol                           VZbase1.pol
    VZbase2.pol                          cc_logs/
    dhcp-reply.pcap                      dhcp-reply.pkt
    dhcpreply.pkt                        dhcpresp.pkt
    dhcpresp.py                          lost+found/
    nsi.dmp                              nsi_last_req.dmp
    nsi_new.dmp                          nsi_re.dmp
    old_nsi_first_req_after_reboot.dmp   old_nsi_last_req.dmp
    primary.cfg                          rest.tar
    rest/                                ssl/
    test.xsf                             vmt/
        This command was first available in ExtremeXOS 31.4.
